right out of the start I have problems
Captbo
Hello Friends, I have a 12 volt string of 50 RGB pixels, I have a 12 v power supply I have a Nod mcu. I downloaded, the control program and tried to "flash" the nod with the same Using esphome flasher I could not locate the com port on my windows Lap top, I went to my device settings and I found no ports I have three USB ports? can someone give me better instructions, Thanks Bo
You'll need to put the Node MCU into "flash mode" when powering it on.
well must be driver related I pressed the button and got the same result
Thank you, THius is what I get
Try these drivers, I found one of them worked on my Win7 PC
Check that you are not using a charge only USB cable. Try another cable.
