RTC battery error
IF you have a Hanson Electronics board with a realtime clock installed please read https://www.hansonelectronics.com.au/realtime-clock-battery/
The list of boards that contain the TinyRTC module and may be affected are
  • Octoscrolla with RTC
  • rPi-28D and rPi-28D+
  • HE123, HE123Mk2 and HE123D
  • rPi-Clk
  • rPi-LedClk
There is a circuit modification that should have been made to allow the use of non rechargeable CR2032 batteries rather than chargeable LIR2032 batteries and in some cases this modification may have been missed.
Is this the cause of the one that was posted on FB this week with an exploded battery? I've only got a battery in one of my He123Mk2's that's in storage, so I'll pull it out and check
I have no idea if that caused the exploded battery. It was seeing that that made me wonder if I'd ever missed any of the diodes. I have 1 of my rPi-28d's that has been permanently installed for a few years now and I "think" it has a battery in it. It only gets turned on a few hours a night over December but I'll have a check before I power it up again.
Where is the diode in question located on the HE123MK2 boards, the website doesn't show in for those boards.
It is mounted on the blue RTC module where you place the battery. It's on the underside of it (between the HE123 and the daughter board) - you should be able to see it face-on the same as the other photos shown.
  • Like
Reactions: AAH
As Skymaster said it's under the clock module and it's somewhat hard to get a good viewing angle. Pulling the Beagle off and measuring the voltage is the easiest option.
