S-200-5 Power Supply (Hanson) and Baldrick 8 - STl
Renzo1975
Good morning all,
Got my Baldrick 8 and S-200-5 power supply all delivered and ready to use.
Does anyone happen to have an STL for this power supply to mount the Baldrick 8 on at all?
There are STL files on the website but they seem to be meanwell.
Thank you.
i also got chat gpt to generate one if that helps, sorry im talking so much
  • Baldrick8_to_LRS200_RightHand_SelfTapM3.stl
  • Like
Reactions: AAH
Is there anything special that you have to do to get chatgpt to do stuff like that? I had no idea you could do stuff like that.
Hey thank you.. I did find an STL on the Baldrick 8 site but said it's for Meanwell. Mine's a SCOTT S-200-5 so i'm going to print it out and see how it goes.. I think about 2ishmm difference if I measured right so I'll report back..
Thank you for your help tho
  • Like
Reactions: AAH
Keep in mind the Baldrick 8 also has the same form factor as a Falcon SRx2 (8 port) Smart Receiver. I believe even the mounting holes are in the same location to allow you to use exactly the same mounts. @domhodgson can confirm :)
So, you might also want to use that in your searches rather than the Baldrick as well.
That is correct, we wanted people to be able to reuse mounts they'd already made / designed :)
