Just making up an arch and the Pixel strip need to be trimmed down to just under 4M, decided to make them 125 pixels long, 375 channels per arch
Here's how i soldered some wires and sealed the cut end.
Cut End
Just push the tube back a little and hold in place
At this point i soldered on wires only to Gnd-SD-CK.... the wire is only there to grab onto rather than for use.
Next pulled tube back down over joint and injected silicon inside tube
Next slip some clear heatshrink over the joint and add some more silicon
Next heat-shrink shrunk using hot air gun. expect a little silicon to squeeze out, i always see this as a good thing and then just clean up with a tissue to remove the excess.
Phil
Cut End
Phil
