Second monitor not displaying layout and sequencer
PIPPAESP
Having a little trouble with xLights not displaying onto a second screen. Works fine on the laptop monitor but does not render any of the sequencing info onto a screen.
Is this a common fault, is there anything that can be done to use both screens to allow for easier and larger previewing?
If you using windows don't use maximise. Click the square at the top right between the - and X and drag it about until it fills the screen and stretch it across two monitors. I run 2 monitors for sequencing and have the house preview on my console's TV. Saves space and when viewing i don't have to squint. :)
If you're using Windows 10, I've noticed there was a big update recently, and I had audio issues as I needed to update some drivers as part of it, so maybe check that too.
I have seen that. I just rendered it again and it came back. Hope is that simple for you too.
