Seed Pixel mounting strip - 3D printed - Published on Thigiverse
Realised overnight that the conduit clips needed an anti-rotation option so back into F360 and test printed... did find out that printing them solid was not a great idea.... to many perimeters from the previous print and i broke one..... ooops. the 16x10 is a tight fit and anyone that plans to print is advised to test print for size.
My printer is printing about 0.2mm under design dimensions and everything is really tight
@AussiePhil, I finalised my design and printed the gutter hooks you’ve provided. They fit nicely and easier to get onto the gutter but aren’t as tight a fit as the ones I have. Both will do the job though. Nice work on the PVC pipe bracket, looks awesome. I’ll share the STL in another post.
Some other pics of the gutter hooks.
I would be super keen on something for a seed matrix, I’m building one at the moment using garden trellis and this would be much easier. This is from Your Pixel Store.
  • 16MM_Conduit_Gutter_Hook_no_standoff.stl
A huge thanks to Rob from the FB group for sending me some samples. I wide variety of types and sizes, details below
1 to 5 fit and insert with no issues, 6 however is a newer bigger one from 2024 and will need a tweak to the design
1. BTF Lighting 5v 10cm spacing 3-wire
2. Maybe Knowshine 3cm spacing, 5v 3 wire.
These fitted spacing wise very well and easy to insert.
3. GL 12v 10cm 3 wire
4. GFL 5v, 5cm spacing, 2023, 3 wire.
5. Know Shine 5v 5cm 4-wire
It was good to see that both 3 and 4 wire seeds fitted.
As i can only add 6 images post continued...............
..... continued, the only one that did not fit was the new 4 wire
6. Know shine 5v, 5cm, 4-wire 2024
they are relatively quite larger in bulk than the rest and will need a tweaked design, whilst i would prefer a universal design it may be better to make 2 versions
These like a good replacement for my strip on round conduit, but printing 20mtrs+ of the seed mounting in 300mm lengths might take awhile :|
Well done on the 3d designs :)
This looks very nice. I would replace my window frames with these. Only problem is I don't think the conduit is available in the US to mount these to.
Been looking through, is there anyway you could change the mounting hardware and joiners for the 16X16mm deta trunking?
