Seed Pixel mounting strip - 3D printed - Published on Thigiverse
Realised overnight that the conduit clips needed an anti-rotation option so back into F360 and test printed... did find out that printing them solid was not a great idea.... to many perimeters from the previous print and i broke one..... ooops. the 16x10 is a tight fit and anyone that plans to print is advised to test print for size.
My printer is printing about 0.2mm under design dimensions and everything is really tight
@AussiePhil, I finalised my design and printed the gutter hooks you’ve provided. They fit nicely and easier to get onto the gutter but aren’t as tight a fit as the ones I have. Both will do the job though. Nice work on the PVC pipe bracket, looks awesome. I’ll share the STL in another post.
Some other pics of the gutter hooks.
I would be super keen on something for a seed matrix, I’m building one at the moment using garden trellis and this would be much easier. This is from Your Pixel Store.
  • 16MM_Conduit_Gutter_Hook_no_standoff.stl
A huge thanks to Rob from the FB group for sending me some samples. I wide variety of types and sizes, details below
1 to 5 fit and insert with no issues, 6 however is a newer bigger one from 2024 and will need a tweak to the design
1. BTF Lighting 5v 10cm spacing 3-wire
2. Maybe Knowshine 3cm spacing, 5v 3 wire.
These fitted spacing wise very well and easy to insert.
3. GL 12v 10cm 3 wire
4. GFL 5v, 5cm spacing, 2023, 3 wire.
5. Know Shine 5v 5cm 4-wire
It was good to see that both 3 and 4 wire seeds fitted.
As i can only add 6 images post continued...............
..... continued, the only one that did not fit was the new 4 wire
6. Know shine 5v, 5cm, 4-wire 2024
they are relatively quite larger in bulk than the rest and will need a tweaked design, whilst i would prefer a universal design it may be better to make 2 versions
