Sequencer now not starting shows
Baf05
Canberra
I have done test after test, and everything was working fine.
Did a restart of my computer yesterday after a windows update, and now it Sequencer wont work at all.
I have tried uninstalling, reinstalling, I cant even make the Sequencer manually play...
And all this last night when I am supposed to be starting my first full show tonight!
Anybody got any ideas
burner
Try the following:
Delete your show from the scheduler
Delete c:\windows\temp\*.*
Delete %temp%\*
Delete C:\ProgramData\Minleon\LightShowPro\Server\ClientFiles\*
Open Scheduler and put your show back together
Watch the Task Manager (sorted by CPU use) and wait till the LightShowPro Services has slowed right down and the system is 99% idle
Change your machine time to 2 minutes before the show (to test) and see if it runs.
After you have added your schedule in, the show won't actually work till it's all optimized.
Baf05
Canberra
not actully sure how to do any of that.
I have unisntalled again. I am going to redownload from the LSP website and try that....
Why not just remove the update that caused the issue as you can select the updates you want to remove.
