RiverBendLights
- Oct 21, 2014
Ideally I could just plug my e1.31 Ethernet switch into my router, give it an IP and access the lights from a computer on the network... not sure if this is possible, maybe someone can tell me.
Another thing I thought of was making a separate wireless network and connecting 2 wifi routers to each other one to the show and one to my PC or just putting the router near the show ethernet switch and using the wifi to connect to the show router. Is this a bad idea? is wireless a bad idea? I think the IP thing could work well if it is possible. basically like this http://www.doityourselfchristmas.com/wiki/index.php?title=File:Routerconnecte131.png but I would connect to the router wireless, so I could control the show from any computer wirelessly connected to the network.
Otherwise I have wifi on my show computer and an Ethernet port. I could dedicate wifi to the internet and the Ethernet for the show and just run cat 5 through my house from show PC to the outside of my house. I can run the wires, but my question is it worth it, or should I try something else like I mentioned
Edit: I found this http://www.lightjams.com/sacn.html not sure if could do what I'm looking for and what it requires to setup. Have any of you used it?
