nutz4lights
Hello Aussie Lights folks...
First post here, so I figured I'd make it a doozy. Making my way here from Planet Christmas because of the resident experts in the field of RGB lights, which is something of interest to me... Was over at Planet Christmas since probably 2006-ish. Been an LOR user my entire time in this crazy hobby... looking to jump into either dumb pixels with LOR DC or smart pixels with E1.31 from J1SYS... Wanted to add that, although I've never been to Australia, my wife and I did make it most of the way there (Fiji) for our honeymoon and our interactions with all the vacationing Aussies was a good one... top notch nice folks.
My question (up front) is that I have read topics mentioning that the cost of dumb pixel setups starts to approach just going with a smart pixel setup for some applications. It kind of blew my mind because the cost of the smart pixels is nearly 2X that of the dumb pixels from Ray Wu. One area where I've seriously considered doing RGB is on my plethora of wire/stick/twig trees, so I thought I would try to work through the numbers and see which made sense. I'm hoping that folks here can go through this and make sure I have a good grasp on this because the smart pixel option is more than 50% more for this application by my calculation.
So, for years we have used a bunch of the twig, stick, wire trees. I had around 10-15 of them and then last year after Christmas managed to pick up another dozen or so on sale at Sears. For anybody that is unfamiliar, they look like this:
http://www.sears.com/shc/s/p_10153_12605_07111040000P?vName=Seasonal&cName=Christmas&sName=Outdoor%20Decorations%20&%20Figuresmv=rr
They typically come with anywhere from 300-600 lights depending on height. So, for years I have taken the 400 or 600 light versions I have and added a comparable amount of red and green. The lights are too heavy and it makes the twig branches bend (they are flimsy metal) and over time they break. I thought it would be great to replace the three color strings with a single string of RGB pixels, greatly extending the longevity of the trees before the branches are all busted. I am going to use 400 lights per tree in the example below, which would probably end up getting reduced, but at least I am comparing apples to apples.
Some things I am assuming:
- three trees per LOR controller is because of current draw (1200 nodes x 0.3W = 360W and a fourth tree would absolutely max out the LOR controller's 480W rating for 12V @ 40A)
- two trees per J1SYS ECG-P2 controller is because each tree would be four universes of 100 pixels each and there are two channels of four universe capability on the P2 the way I'm reading it)
Dumb RGB Pixel Approach (using 12 trees to most efficiently use LOR controller)
400 nodes x 12 = 4800 nodes @ $0.25 per node = $1200
each LOR controller can do three trees so 4 x $99 = $400
each LOR controller needs dual 240W power supplies so 8 x $20 = $160
each LOR controller needs some form of casing for the controller and power supplies so 4 x $50 = $200
Total = $1200 + $400 + $160 + $200 = $1960
Smart RGB Pixel Approach (using 12 trees to most efficiently use J1SYS controller)
400 nodes x 12 = 4800 nodes @ $0.45 per node = $2160
each J1SYS ECG-P2 controller can do two trees so 6 x $68 = $410
each J1SYS ECG-P2 controller needs a 360W power supplies so 6 x $25 = $150
each J1SYS ECG-P2 controller needs some form of casing for the controller and power supplies so 6 x $50 = $300
Total = $2160 + $410 + $150 + $300 = $3020
So, did I do the above math correctly? I think the smart pixel approach would be very cool because the shimmering of individual pixels on the trees would look great! The thing is for $1100 extra... I could build up a megatree with smart pixels based on Fast Eddy's design...
Thanks for the comments / dialogue! I appreciate it.
-Louie in Melbourne... Florida
<yes, I really live in Melbourne, FL, and its not nearly as nice as the pictures I've seen of Melbourne Australia
