Gooliez
I'm burnt out.. in the last 24 hours i've had Xlights completly reset itself, had to manually map all the strings for 24 runs again. Lights not lighting. lights lighting when you turn another model on.
now i have this issue. The 6 small outer matrices and the frames around them. All one string.
The left side are working perfectly. then it's like it's been cut off and all major issues on the right. they are lighting up, kind of.
it's the only string lit up on the board. so theres tonnes of power.
Doing a RED test mode at 20% so you can see it better in the pic. All left are fine, but 4 basically isnt lighting, Half of 5 is blue, All of 6 is blue. ( thought i'd try this without power balancing)
If i power Balance they flicker badly, regardless of what power level and sometime they just turn off all together. Voltages are sitting at 10.1 at the start / end of strings and 6.2v in the middle where the issues start to happen.
Also have a Star on megatree that flickers.
its at the end of the second half of megatree, 450 nodes for tree, 150 for star. flickers ONLY on the star.
I dont know what to try. Power balancing doesnt seem to effect it. it's only happening on this VERY specific string. all the rest ( apart from megatree star) work perfect.
What would be causing these 2 strings to have issues?
