Srmorgan
- Jan 26, 2020
I am using a falcon f16v3 with 2 smart receivers. I am testing one at a time, and cant get them to light the correct way. Well actually I've only tested the First one because the other is on the roof. I am using 5v psu running at 5.3v, I have the f16 Running version 2.56 hooked into the router and the smart receiver hooked into the first dmx port. The receiver is set as receiver A and set up that way in the f16. The terminator switch's are in the on position. I have 50 ws2811 lights hooked to Port 1 and 2 on the smart receiver. The test button functions fine. But I cannot get a test to run from the f16 and when I try to run a sequence from xlights it doesn't work. Now when I say doesn't work I should clarify. Usually when I start a test from the f16 or run a sequence the lights all turn on full bright. Or at least most of them do. Usually there is a light or two that is a random color. Some times when I start a sequence or test from f16 the lights will start to flash/blink but stays white. When I stop the test, the flashing stops as well. I will try to get a picture of the f16s setup and add it to the post later. I'm not sure what to do next and I'm not old enough to loose all my hair yet. Has anyone dealt with this?
