I am testing actual lights on models and setting up controllers. I have hinkspix pro and my mini tree is connected to port 1. I run test in xlights and works great. I set up another mini tree to port 2 and can't get it to work. I pushed the test button inside the receiver and both light up. I go into hinks pix web page and try to test and only the tree connected to port 1 lights up. Missing something simple I am sure. Here are some screens hots. The pic with the red lines are the 2 trees im setting up. I've attached configuration for each tree. If I manually hit test button in receiver both light up. When I test on web page, only the port 1 tree works as well as in xlights
