So I thought I would add some tips on strip lighting, as basicallly my whole display (except for mini trees and reindeer which use the WS2811 nodes).
I have about 200m of WS 2811 3 led per pixel strip on my roof alone. I have 6 matrix’s on my house, a 4m x 12 strip tree and a large 14.6m x 4 strip matrix across the front as wel as spinners and house outline.
So after a few years and learning a few things along the way, strip is very reliable, economical and easy to repair.
1. Solder joins - these can separate, especially in hot weather. To combat this I place a large cable tie over solder joins in the strip and tighten well. This pretty much eliminates this problem.
2. All my strip lights are cable tied to 20mm electrical conduit (32mm for mega tree). On the ends where the connections jokingly ther is an additional cable tie to stop the join from flexing. Strip is not rigid and to assist this, the joins need to have as minimal movement as possible.
3. Not all strip is created equal. When I first got my roof strip, I had issues with the power injection and these end connections disconnecting and failing (didn’t have this issue with the house matrixes and mega tree). Upon closer inspection, I found the older strip had 4 pads, which were larger then the new strip, which only had 3 pads which were much smaller. The older strip had 1 pad for +, 2 in the middle for - and data. I noticed that you could get a lot of more solder and have a much more solid - join on the older strip. On the new strip, because of the double wires for both + and - on the one pad, these would fail and fall off much easier.
I had some extra older strip left over this year , so for the roof lights in particular, I replaced the first pixel with the older strip to get a solid connection on the first part for all power injections and none of these failed this year.
4. Short circuits - these occur at time particularly with the heat. The good news is that it doesn’t necessary mean you have to replace a pixel and/or strip. Sometimes a building up on the solder joins can occur, which can easily be fixed by cutting a small hole in the sleeve and using a smalll metal object like a screw to scrap between the solder joins on the pads to remove any short. You can then add a small dab of silicone over the cut (this saved me from having to replace multiple strips as per previous years.
5. Replacing bad pixels ( mainly ones where a a colour has failed) - there is an art to it, but I simply cut out the dud pixel, and using a clamp solder a new one in directly on the pads. I put a clear heat shrink (about 16mm) over it and then shrink it over the connection, puting a small dab of silicone in it before shrinking.
6. For my roof lights, I also add a clear section of 20mm clear hose about 20cm long on the top of the light and conduit going over the connections at the top of the roof, to help keep it rigid and deflect water from being able to get in and run down the tube. Even though rated water-or roof, with a good downpour, water will find its way into any small hole.
For my matrixes, spinners, mega teee which are 3-4 years old now, they have all worked with no faults since installed, even through heavy downpours. But this was the original 4mpad strip as wel
7. Get ray to make custome lengths. I did this for the roof. I measured and had it made to length. You will save a lot of time, plus usually the joins direct form the factory make it easier instead of soldering lots of power injections on yourself.
I will be buying some more strip to replace some sections , but I would recommend spending the extra $1 per metre to get the 4 pad, as I will be going into my 4th year with these still working fine, as compared to the 3 pad strip, although cheaper, requires a lot more maintenance.
He is a video of my display below.
I for one will still be stripping
View: https://m.facebook.com/story.php?story_fbid=1989539548000698&id=1494906617463996&_rdr
