L Ltmup Full time elf Joined Feb 1, 2020 Messages 101 Oct 17, 2021 #1 Has anyone put a CZU-05 in a large ish metal enclosure, obviously this will affect it but by how much? any issues with fans causing interference ?
Srmorgan Full time elf Joined Jan 26, 2020 Messages 103 Oct 17, 2021 #2 What if you add an extension onto the antenna so that is outside the box. That should cut some of the interference.
Notenoughlights 400,000+ twinkly lights Joined Oct 16, 2016 Messages 783 Location Christchurch, New Zealand Oct 17, 2021 #3 The metal box may completely block the signal, as Srmorgan has suggested, mount the antenna externally otherwise you have yourself a fine faraday cage. Does the box need to be metal or completely metal?
L Ltmup Full time elf Joined Feb 1, 2020 Messages 101 Oct 17, 2021 Thread starter #4 curious to know how it would go as is. will probably have to go with something like you suggest. it only needs to go 40 or 50m with clarity
L Ltmup Full time elf Joined Feb 1, 2020 Messages 101 Oct 17, 2021 Thread starter #5 external it is. faraday cage it would be
