Turning on Power supplies
Johnnyboy
Perth
I got one of the Shelly 1pm plus relays like you. Could you take a picture of how yours is wired up?
cheers
Here you go. Grey/orange wago thing is just so I can disconnect the whole bottom plate without removing extra wires. You don’t need that.
Also, if you only want to control via wifi, you won’t need to connect a manual switch (which are the two loose brown wires going up to the switch not shown in the photo)
hope that help :)
algerdes
Al Gerdes
Lebanon, Illinois
Please forgive the off topic (sort of) question. The image attached is a capture of the above focused on what looks like a Wago. The thing is, looking at it closely it looks like the three ports go through instead of the "normal" Wago of being a buss for connecting 2,3,4 or 5 wires.
Am I seeing this correctly?
Johnnyboy
Perth
Yes! I found them on AliExpress. They have quite a few different configurations but I wanted the 3-3 setup. I thought i could use it for emergency pixel repairs as well as for the 240v stuff. (no water resistance, but as I’m in Perth it would do till the next day where I could solder it)
Iain
Darwin
A delivery arrived today:
These things are freakin awesome! I have a voltmeter, power meter, bluetooth, wifi, voice control, and endless settings to tweak!
videoman3857
Glass House Mountains
I have 7 central control boxes spread around the property connected to separate power circuits .
Each contain 6-8 x 350Watt PSU and each switched central control is individually turned on by digital timers.
