Whitey-
Hey all,
Has anyone come across an issue where after adding a new controller to xLights, FPP is mapping all the sequences created prior to that controller being added?
I added a new controller (Prancer) in this afternoon before my show tonight so I could move my arches onto it (as power injection is a problem in the yard). As part of this movement, I did need to change the universes around.
My sequences all work fine on WLED, and in test mode in FPP. They also work fine if I direct output from xLights sequencer. However all the sequences I've created before adding this controller have the lights wrong - for example my first sequences is singing faces chatting, and the faces are lighting up, but on lights over on the spinner.
I've tried creating a completely fresh sequence and lighting up specific props - no problems. But any old sequences I cannot fix.
I suspect my older sequences are still mapping to the older universe/channel numbers from before. I've re-rendered and re-uploaded to FPP a number of times though to no avail.
I'm sure this one's obvious, but nobody's in the zoom room and I can't find anything searching the web. Show starts in an hour, so any help is very much appreciated!
