This question comes up a fair bit in chat. People want to use LOR software and 3rd party DMX controllers. So, what are the options?
If you buy an iDMX1000 LOR-DMX interface, you can connect your 3rd party DMX controllers to that. Just be aware that the iDMX1000 is not cheap and there is a limit to the number of intelligent channels it supports.
The other way you can go is to use LOR S3 software with an "open DMX" style dongle. You will need to have the "Advanced" version of the LOR S3 software however. As the software is a one-off cost, this will work out much cheaper than using multiple iDMX1000 interfaces.
The LOR USB485 dongles are actually "open DMX" compatible so can be used instead of buying a new dongle. Unfortunately the pinout of the RJ45 connector on these is different to the ESTA standard pinout so you'll have to buy or make a simple wiring adapter.
