Vixen 2 + Da_DMX & LORD
aaronwa
Perth
[SIZE=small]Hi Guys, [/SIZE]
[/size]
[/size][SIZE=small]Brands new to computer control. I currently have; [/SIZE]
[/size]
[/size][SIZE=small]1 x LOR CMB16D-QC[/SIZE]
[/size][SIZE=small]1 x USB controller [/SIZE]
[/size]
[/size][SIZE=small]I want to use Vixen for a test. I have connected everything and run the DA_DMX software on my machine. i've opened the port and the test flash is working on my lights. [/SIZE]
[/size]
[/size][SIZE=small]How do i now confuigre the vixen software to connect to my LOR board. Help would be greatfully appreicated :) [/SIZE]
[/size]
[/size][SIZE=small]- Aaron [/SIZE]
With Vixen 2
Sequence -->> New Event Sequence -->> Vixen Standard Sequence --->> Next --->> Next --->> Next
Edit the channel names if you want to --->> Next-->> Setup Plugins (You need the Entec Open DMX, Adjustable preview is the visualiser you'll refer to)-->>Done
Assign Audio (You'll need wizrds in winter as this is the Xmas staple).
Next -->>> Create It---- Save it as a name.
You should then be pretty much ready to create a simple sequence.
davrus
Silent elf
Whitianga
If you are just starting, then it probably is better to start with Vixen 3, rather than Vixen 2.
