3.x Vixen 3.2 lipsync Problem - fixed
Discussion in 'Vixen' started by damo1271, Nov 9, 2015.
  1. damo1271
    damo1271 Full Time Elf
    Oct 12, 2011
    197
    5
    Adelaide
    I was having some problems with the lipsync function in Vixen 3. (Version 3.2 build 115)
    I had 4 singing trees and was trying to set up a lipsync map for each of them.
    However whenever I tried to add the second map Vixen would just crash/exit. No matter whether I tried to add the second (or third or forth) map as separate maps, or add the second, 3rd and 4th elements to an existing map the same result - Vixen just crashed/exited.
    After spending ages looking through the Vixen issue database, the problem it seems could have been related to using copy and paste when adding the elements in the display setup process.
    The solution: (this may not be the only solution but it worked for me)
    Delete each element in the vixen display setup screen and re-create from scratch! Do not use copy or paste during the process. Create new maps and this time they worked perfectly - no crashes/exits.
    Hint, if you have a default map you can create the new elements based on the default map. I didn't know this prior and its really cool.
