Is this the box you are talking about?hdracer said:At home depot & lowes they have a box that is large enough to do so. ill see if I cant find pics
I know Shellnz is using the box im talking about, as I am too.
scott4864 said:Is this the box you are talking about?hdracer said:At home depot & lowes they have a box that is large enough to do so. ill see if I cant find pics
http://www.homedepot.com/p/Orbit-Outdoor-Timer-Box-57095/100158884#.UfMrcowo59A
RayKob said:I recently purchase that item and i am very dissastified with it. It is designed for out door timer and has a pre mounted power outlet and a center post to support the mounting plate. Looks like you would have to do alot of cutting to add anything to it and even then i don't see two 30amp supplies fitting along with the P12S board. I found this item to be a waste of money. Take a look at the following:
http://store.creativelightingdisplays.com/Enclosures_c19.htm
logandc99 said:I've used the cg1500 boxes as well. I've had to use two boxes per p12s setup, one box containing the two power supplies (the fit is fairly snug) and a sep box for the P12s. I had ordered about 6 of the boxes from creative lighting displays last year. They are $15.95 each US. Unfortunately postage was about expensive out to NZ but still worked out way cheaper than buying anything here.
