What tool/accessory/gadget do you think we should all get?
Katekate
Portland, Vic
I'm all for making things easier on ourselves. what have you found that you think we should all have?
Test radio. I have this one. https://www.amazon.com.au/dp/B01ARN28SQ
I used to use one with an analog tuner, but last year my transmitter got bumped and was on the wrong frequency, and I didn't notice because of the analog tuner.
So I bought this one with a digital tuner so I can verify frequency when I check the show each night. its a nice compact size, and it recharges with usb-c.
The other thing I'd like to recommend is a kneeling pad. - https://www.bunnings.com.au/citeco-kneeling-board_p0479869
I like this one because of the solid backer. it will bridge over metal roofing and always give you an even surface, and because its hard plastic you can actually scoot it sideways on the metal without standing up.
What would you like to share?
I'll 100% agree on testers. Just this year I was thinking it is time to get a network tester to check my cables to make sure they are working properly without just the swap and hope game. The network tester can help with finding network data issue, and just general cable health checks. This will allow me to just make specific length cables and test them to be correct.
Pixel testers are very useful also and I need to get a new one. I reversed the output polarity on my F-Test and it has not been the same since. I can't even to begin to say how annoyed I was not to be able to properly test strings and need to buy a new one.
Some sort of mobile organization system like either carpenters belt and bags or a vest with many pockets that a photographer would use. I have a small tool bag I carry around that I have to dig through to find what I need and 25% of the time what I want is somewhere else.
Duplicate tools! I'm not sure about others but I have multiple places to work on my stuff depending on year, weather and if the show is running or not. I'm really tired of having to run back between my garage and my work desk in the basement when I forget a tool because I was fixing things outside or building things in the basement.
1. Pixel Push / Pull tools are not used a lot but very nice when needed
2. Wire Cutters
3. Wire Strippers
4. Pliers
The one tool I carry at all times during setup and takedown is a pair of flush cutters. I use them to trim zip ties without leaving a sharp edge, cut zip ties off things, trim the excess coro when I drill through it, cut wires, and whatever else I might need to trim or cut.
These are actually my favorite, with the added bonus that they're cheap:
Beginning to think I'll need a cherry picker at some point.
Rj45 crimpers and crimps are something I'll always have on hand.
Multimeter for sure
Thermal camera to see if there are any obvious issues before they become bigger.
Various ladder sizes and straps to tie them against something if I need to go vertically up
Soldering iron and (not always needed) portable power source because finding a plug sometimes can be difficult
Multimeter
Soldering iron (bonus points if you have 1 powered by Makita battery or similar)
Side cutters (preferably flush cut)
Pixel tester and/or F-Tester
Ethernet cable tester
Multimeter
I was hoping people would recommend specific items. Since its in your wheelhouse Alan, do you have a meter recommendation?
I bought a china made fluke last year since it was nice and compact and it died about the 3rd time I used it.
I reckon an F test would be handy. I've got a basic smart receiver and power supply in a box I use at the moment which works ok. But limiting when I'm trying to count pixels.
I have one of these multimeter and has worked without any issues for 4 years. I think it’s a good price with out being to cheap or to expensive.
Multiple Klein Multimeters here and highly recommend. Getting one with DC clamp ammeter to test current draw on strings, etc is nice when testing things. My go to is my CL2000, its old but still going strong. Clamp Ammeter rated for 400a DC has come in handy here
The choice of multimeter isn't important as long as you know how to use it. An autoranging 1 is definitely more handy than 1 where you have to select the range. My most recently purchased mutimeter has an oscilloscope built in. I've probably got about 10 multimeters around with some cheap $5-10 ones kicking around in the cars, a Fluke which is the only 1 I have ever had that's died, a couple from Jaycar that include temperature measurement, a true RMS 1 and also the new 1 with a scope built in. My go to 1 most of the time is an old Nilsen 1 that has an awesome continuity tester. It will give an audible indication if there is even the smallest momentary break or short when testing.
