I had always believed that you could run up to 1024 Pixels on a single port. However, as I am currently using a Falcon F16V3 Controller with 4 x Differential Receivers, I’ve had to split that number over both devices (e.g., 512/512). Currently my largest prop has 500 Pixels in it, and in the past, it seemed to work properly.
However, recently I’ve heard people saying that 800 Pixels per port is now the maximin.
This year I’ve ordered some new Props that will have 823 Pixels in them. I’m not sure if I’ll adjust by Falcon F16v3 pixel balance to something like 823/201. However, I’ll probably just use my old 4-port Pixlight Controller to just run these larger props.
So, I’ll really need to work out if that 800 Pixel per port is now relevant (or if there is any creep allowed e.g., up to 823), or is the 1024 limit still the one I should work to? It would be great if someone could give me the low-down on this.
If that 800 Pixel per port is the new standard, can anyone advise how I should now go about showing a Prop over two (or more) Ports in xLights? With the introduction of the Visualizer in xLights, it’s made the process of working out Ports much easier, but I’m not sure how it would work with a prop with more than one port. Once again, if anyone could advise how to do this, that would really be appreciated.
