joeengler said:So I have everything ready now, have one more question. (sorry if it has been answered on another post)
I know that there is a in and out for the strings (Item-1) does the voltage follow the same in or out. If not I understand how to power both strings at the base, if not how do power them from the base?
My thinking is I connect the data and clock at the top then feed the power to both strings from the bottom
Power can be fed from either end as all the power does is just connects in parrallel to all the other pixels. The data is connected in series so there is an in and an out.
So generally people will connect both the data/clock and power to the input side of the string/strip and then inject power between each connected string/strip. Some will supply power from both ends of the string/strip, others have supplied power to the output side only
