Whole House Model - Unable to move some models
Habbosrus
Back again
Swansea, NSW
I need help. I made a whole house model which seems to work well. However, I have 2 models which are at the top of my preview. I am unable to move them up any higher (or move them at all now). I had been moving them toward the top of my preview when I went off screen with my pointer/cursor/mouse. Now I can't move them at all. The point with which the elements/models are moved is well above the actual model/element itself. Are there any tricks to being able to move these? I have attached a picture showing the models/elements (stars) I wish to move. You can see that they are not right at the top of the preview screen, yet I am unable to move them. Any help would be greatly appreciated.
mararunr said:
Have you tried adjusting the size slider on the left? Sometimes that helps when I'm having trouble with models.
Yeah, I've tried the slider, preview size, clicking in different places on the preview, but so far nothing is working. Thanks for the suggestion. I'll keep trying.
make sure your display size is not too large, this is a bug that causes selection problems.
i use 1200x800 as resolution.
if you open the xlights_rgbeffects.xml file and go to the model you want to move
Example: xlights_rgbeffects.xml, look for
offsetXpct="0.4937"
offsetYpct="0.6177"
This indicates the ecnter of this model will be drawn 49% in the x direction and 61.7% in the right. bottom left corner is 0,0
just edit these two values to be 0.0,0.5 and the object will be centered dead in the middle of the preview screen.
<?xml version="1.0" encoding="UTF-8"?>
<xrgb>
<models>
<model name="Soffits" DisplayAs="Single Line" StringType="BGR Nodes" parm1="1" parm2="194" parm3="1" StartChannel="663" StartSide="B" Dir="R" Antialias="0" ModelBrightness="0" MyDisplay="1" offsetXpct="0.4937" offsetYpct="0.6177" PreviewScale="0.5600" PreviewRotation="0" versionNumber="1"/>
offsetXpct="0.4937"
offsetYpct="0.6177"
This indicates the ecnter of this model will be drawn 49% in the x direction and 61.7% in the y direction. bottom left corner is 0,0
<xrgb>
<models>
Thanks Sean, I'll give it a go this evening.
I have the same issue, regardless of how I edit the file...some of them I can move, others I can not
Works best in 640x480
-Blu
