Wire gauge for PSU to controller?
FrankO
Newy
Trying to get my head around wire gauges etc...
What size wire should I run between PSU's and F16V3?
I have a roll of this laying around, would it be adequate?
darylc
404 darylc not found
Assuming you want to power lights through the F16v3 you would probably want 30A capable cable for connecting each side of the board to power supply
FrankO
Newy
Thanks. What AWG would that be?
paullyxmas76
Baldivis
I use this cable on all my connections to PSU's and distro boards rated to 22amp@12VDC...works in my application as I run pretty much all power supplies at 350W 80-85% of their full capacity 22-24amp at 12VDC
There is a bigger version rated at 50amp and I have used this also for larger amperage and longer runs but is over engineering
