Wireless Temp Monitor Receiver an the Wireless Temp Transmitter/Fan Controller
SmartAlecLights
Murray Bridge, S.A.
Time to introduce you to another 2 of my projects i now stock. (stock levels are currently low)
These are Arduino Based Projects an use's easy to replace modules.
(Arduino will be Pre-Programmed, but source code can be supplied upon request{to custom label 6char})
Wireless Temperature Monitor Receiver
Specs :-
  • Receives data from as many as 4 Wireless Transmitters,
  • Has Internal DS18B20 Temp Sensor, (for Inside room temp)
  • Displays received wireless data with a 2sec refresh rate,
  • Displays Sending Temp Fan speeds via VU meter,
  • Has a External Antenna, (to receive wireless through walls)
  • Detects if a transmitter fails to work or not connected,
  • Board Operates on 5v (can be used on 12v if stepdown converter used)
Wireless Temperature Transmitter/Fan Controller
Specs :-
  • Has a DS18B20 Probe Temp Sensor, (to monitor temps in Hot Spots)
  • Control's up to 2 fans (5v to 36v @ 500ma each fan),
  • Fan power is a separate input (5v to 36v),
  • Fans are Speed Controlled in 5 steps depending on Temp Range <25c = off , >33c = full on,
  • Sends Information via Wireless to Receiver every 2seconds,
  • Board ID is selected via dip switches,
  • Wireless module can be Swapped for External Antenna,
Pricing for these Kits are :-
Wireless Temp Monitor Receiver = $ 35.00
Wireless Temp Transmitter/Fan controller = $ 25.00
Wireless Temp Transmitter/Fan controller (External Antenna module){not really needed} = $ 30.00
Stepdown converters are $2.50 each
Pricing for Pre-Built are :-
Wireless Temp Monitor Receiver = $ 40.00
Wireless Temp Transmitter/Fan controller = $ 30.00
Wireless Temp Transmitter/Fan controller (External Antenna module){not really needed} = $ 35.00
For more info you can contact me or vist the Shop
http://www.smartaleclights.com/shop/
Picture Instructions to build the kits are linked on the shop
Soldering skills for this project is Rated as EASY
Distance Range
During testing i placed the senders around the house an out the backyard
Maximum tested distance was 30 meters going through 3 brick walls
Antenna can not send information if in metal shed or metal enclosure
External antenna module can be used on Transmitters for longer distances
