I have 2 sets of strings where one works fine on test pattern, and one give me wonky colours. The wonky one starts out fine but as it runs the pixels seem to start getting random colours and then gradually all shift to white as the test pattern cycles. Only the very first pixel works, and sometimes even it gets a funny colour.
I think this is a voltage problem but would appreciate any suggestions.
The setup is:
Set #1:
2 strings, lengths 68 and 52. Each string has power applied from its own DC-DC converter, power input at both the start and the end. The 2 converters are on the same PS - same +V and G. Data from the end of string 1 is fed to the start of string 2.
Set #2:
Similar: 3 strings of 50 each, again each with its own DC-DC feeding the start and end of each string. Common +V and G for each converter.
All strings are 5V strings - same make and model.
I'm thinking the 68 long string is too long for the 5V feed. But I don't understand the mechanics of what I'm seeing. Why would the problem start at pixel 2? Wouldn't there be enough voltage to get a few pixels working up front? And why start fine and then get erratic and then go to all white?
I'm going to try putting another DC-DC converter about 18 pixels into the first string. This would be a +5 injection here, or I could split into 3 strings like set #2.
Do I need to connect 5V and G between the strings?
Any thoughts and comments are appreciated.
Bob
The setup is:
Set #1:
Set #2:
Bob
