WS2811 (RGB) - Vs ??? (RGBW)
OZ-Hornet
Hi All
I see a lot of videos where people’s “white” or “sparkle” is bright and clean. Are you using WS2811 (RGB), or is there an equivalent (RGBW) 12 mm available? I have not found one yet.
TIA
Ben
Yes there are IC chips designed for RGBW, such as WS2814. Compared to RGB, RGBW adds in a dedicated white LED.
I personally have not considered this for my display since I find RGB is already bright enough (actually too bright IMO without limiting brightness to well under 100%).
There may be someone else who has experimented with WS2814 or another kind of RGBW IC who could comment further.
The sparkle is usually done with RGB LEDs, not RGBW. I would say less than 1% of people use 4 channel LEDs.
The 4 colour LEDs are much preferred for static lighting - if you say put them under your eaves etc. The "white" channel comes in both cool and warm white variants - depending on what you want do to with it.
xLights can sequence either RGB or RGBW - that being said - it's usually easier to do everything in RGB, and then the controller does a map that on equal RGB values, it engages the white channel instead - WLED can do this, for example.
Some lighting setups dont even use the white channel for xLights/sequencing, it's only used by the static (non-show) architectural lighting.
I use custom LED pucks for the globes in my set-up (since I want a high-powered LED for these props).
These pucks are RGBWA (amber). Power-wise (and managing the heat), I found it better to power a single white LED, than powering each RGB (just to get white).
But for regular nodes/bullets/bulbs, I wouldn’t bother with RGBW.
