WT32-Pixels
SmartAlecLights
Murray Bridge, S.A.
I finely designed another board,
This one is using the WLED firmware, and a WT32-eth0 module
So you get WiFi and Ethernet Control.
This board is only 5v
Each Output is capable of
= 800pixels at 40fps,
= 1000pixels at 30fps,
= 1500pixels at 20fps,
I've provided the option,
For people to buy an program there own WT32 module, (board only)
Or the get the module supplied an pre-programmed. (board + module)
www.smartaleclights.com / WT32-Pixels Controller -- Link
P.S. There is a version 2 being built, That includes Multi-Voltage input, DMX Output, 3x Switch Inputs
very nice!
this would compare to QuinLED dig quad?
can you run this off a battery to keep it alive?
might sound silly but I run QuinLEDs off a 18650 battery charge shield and use the rely feature of WLED to turn the power supply on when the lights are turned on
then once the power supply in on recharge the battery
Different module being used
very nice!
