It's been a couple of years since doing the lights, but trying to get back into it this year.
I run a pi3b, FPP, and DMX2-24 boards and string lights (96 channels this year).
I've finally got my custom model and layout sorted and starting to program some simple sequences like I use to, predominantly using the 'Music Effect' tool/filter. With a quick play on some of the sliders (notes, sensitivity, offset, scale bars etc) I would have a 5 minute song done and saved (auto rendered) in a matter of minutes. However this time round and the current version of Xlights, the rendering is taking an absolute marathon of time. Not sure what has changed?
I couldn't create my custom model the same as last time, but managed to make it them alright in the end. Not sure if this is having an effect or not, otherwise what else it could be? There's no shortage of laptop power on tap and it's certainly not maxing anything out when I have task manager open at the same time.
Any ideas or what I could check? Is it over-rending something invisible or not actually required? For example I just have a 3 strings on the "music effect" for a 4min song and its taken over 5 minutes just to do that. God help me when I have 90+ channels for longer songs.
Ben
2026-11-18 20:32:13.187 [xLights info] SpecialOptions: loaded from exe folder 'C:\Program Files\xLights\special.options'
2026-11-18 20:32:13.187 [xLights info] Start Time: 2026-11-18_20-32-13-755.
2026-11-18 20:32:13.187 [xLights info] Current working directory C:\Program Files\xLights.
2026-11-18 20:32:13.187 [xLights info] ******* OnInit: XLights started.
2026-11-18 20:32:13.188 [xLights info] XLightsSettings: settings file 'C:\Users\send_\AppData\Roaming\xLights\settings.json'
2026-11-18 20:32:13.197 [xLights info] Version: 2026.19
2026-11-18 20:32:13.197 [xLights info] Build Date: Oct 23 2026
2026-11-18 20:32:13.197 [xLights info] WX Version: wxWidgets 3.3.4
2026-11-18 20:32:13.197 [xLights info] Machine configuration:
2026-11-18 20:32:13.197 [xLights info] Total memory: 16384 MB
2026-11-18 20:32:13.197 [xLights info] Free Memory: 9830 MB
2026-11-18 20:32:13.197 [xLights info] Current directory: C:\Program Files\xLights
2026-11-18 20:32:13.197 [xLights info] Machine name: B2_LENOVO
2026-11-18 20:32:13.197 [xLights info] OS: Windows 11 Pro 25H2 (build 26200), 64-bit edition
2026-11-18 20:32:13.197 [xLights info] OS: Windows NT family(XP / Vista / 7 / 8 / 10). 10.0
2026-11-18 20:32:13.197 [xLights info] 64 bit
2026-11-18 20:32:13.197 [xLights info] Little Endian
2026-11-18 20:32:13.197 [xLights info] CPU Arch: x64
2026-11-18 20:32:13.197 [xLights info] CPU: 13th Gen Intel(R) Core(TM) i7-13620H
2026-11-18 20:32:13.198 [xLights info] CPU cores: physical=10 logical=16
2026-11-18 20:32:13.220 [xLights info] GPU: name=NVIDIA GeForce RTX 4060 Laptop GPU | pci=10de:28e0 | memory=7957MB
2026-11-18 20:32:13.220 [xLights info] GPU: name=Intel(R) UHD Graphics | pci=8086:a7a8 | memory=128MB
2026-11-18 20:32:13.220 [xLights info] GPU: name=Microsoft Basic Render Driver | pci=1414:008c | memory=0MB | class=software
2026-11-18 20:32:13.260 [xLights info] Displays: 3
2026-11-18 20:32:13.260 [xLights info] Display 0: 1920x1200 at 0,0 scale 1.00 primary rate=144 rate_max=144
2026-11-18 20:32:13.260 [xLights info] Display 1: 2560x1440 at -1544,-1449 scale 1.00 rate=59 rate_max=180
2026-11-18 20:32:13.260 [xLights info] Display 2: 2560x1440 at 1016,-1440 scale 1.00 rate=59 rate_max=180
2026-11-18 20:32:13.260 [xLights info] Present: allow-tearing supported (variable refresh present path available)
2026-11-18 20:32:13.262 [xLights info] Set VAMP_PATH to 'C:\Users\send_\AppData\Local\xLights\VampPlugins;C:\Program Files\Vamp Plugins'
2026-11-18 20:32:13.262 [xLights info] SpecialOptions: loaded from exe folder 'C:\Program Files\xLights\special.options'
2026-11-18 20:32:13.262 [xLights info] Logger 'xLights' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'render' level set to 'warn'
2026-11-18 20:32:13.262 [xLights info] Logger 'curl' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'opengl' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'job' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'work' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Main thread id: 0x4fd8 or 20440
2026-11-18 20:32:13.441 [xLights info] Vulkan compute enabled: NVIDIA GeForce RTX 4060 Laptop GPU (type 2, queue family 2, graphics family 0, size threshold 8192)
2026-11-18 20:32:13.441 [xLights info] Vulkan: device=NVIDIA GeForce RTX 4060 Laptop GPU | type=2
2026-11-18 20:32:13.692 [xLights info] EffectManager: built 56 effects (56 with metadata) in 429.3ms
2026-11-18 20:32:13.969 [xLights info] If xLights crashes after this log message then the root cause is almost always a problem between OpenGL and their video drivers.
We recommend they download the latest drivers from their card provider ... not from their operating system provider.
2026-11-18 20:32:17.035 [xLights info] Directory for *.xvc files not found: .
2026-11-18 20:32:17.035 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: C:\Program Files\xLights\valuecurves\.
2026-11-18 20:32:17.108 [xLights info] Found 16.
2026-11-18 20:32:17.848 [xLights info] SpecialOptions: loaded from exe folder 'C:\Program Files\xLights\special.options'
2026-11-18 20:32:17.848 [xLights info] Logger 'xLights' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'render' level set to 'warn'
2026-11-18 20:32:17.848 [xLights info] Logger 'curl' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'opengl' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'job' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'work' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Show directory set to : E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show.
2026-11-18 20:32:17.987 [xLights info] Show id: 2f8d39ab-2f38-4a23-9696-6ee587806ee1
2026-11-18 20:32:18.205 [xLights info] Backup directory 'E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\Backup\2026-11-18-203218_OnStart' created
2026-11-18 20:32:18.246 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:18.246 [xLights info] Found 0.
2026-11-18 20:32:18.246 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\valuecurves\.
2026-11-18 20:32:18.246 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: C:\Program Files\xLights\valuecurves\.
2026-11-18 20:32:18.246 [xLights info] Found 16.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:18.247 [xLights info] Found 0.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\colorcurves\.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\palettes\.
2026-11-18 20:32:18.248 [xLights info] ColoursPanel Scanning directory for *.xcc files: C:\Program Files\xLights\colorcurves\.
2026-11-18 20:32:18.281 [xLights info] Found 7.
2026-11-18 20:32:18.281 [xLights info] ColoursPanel Scanning directory for *.xpalette files: C:\Program Files\xLights\palettes\.
2026-11-18 20:32:18.282 [xLights info] Found 10.
2026-11-18 20:32:18.345 [xLights info] Direct2D text rendering enabled
2026-11-18 20:32:18.345 [xLights info] Text rendering backend: Direct2D
2026-11-18 20:32:18.477 [xLights info] XLightsApp OnInit Done.
2026-11-18 20:32:18.552 [xLights info] OpenGL: version=3.3.0 NVIDIA 560.94 | renderer=NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2 | vendor=NVIDIA Corporation
2026-11-18 20:32:18.582 [opengl info] Layout - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:18.582 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.348 [curl info] Adding CURL - URL: https://api.github.com/repos/xLightsSequencer/xLights/releases?per_page=6 Method: GET
2026-11-18 20:32:21.768 [opengl info] ModelPreview - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.768 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.802 [opengl info] Preview - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.802 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.890 [opengl info] WaveForm - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.890 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.912 [opengl info] EffectGrid - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.912 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.945 [opengl info] TimeDisplay - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.945 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:22.364 [curl info] CURL Callback - URL: https://api.github.com/repos/xLightsSequencer/xLights/releases?per_page=6 Response Code: 200
2026-11-18 20:32:42.701 [xLights info] Audio file loaded.
2026-11-18 20:32:42.701 [xLights info] Filename: E:\Micro Controllers\Raspberry Pi\Show Folder\Music\4 Not Xmas\Jungle Boogey.mp3
2026-11-18 20:32:42.701 [xLights info] Title: Track 03
2026-11-18 20:32:42.701 [xLights info] Album: Pulp Fiction
2026-11-18 20:32:42.701 [xLights info] Artist: Pulp Fiction
2026-11-18 20:32:42.701 [xLights info] Length: 188917ms
2026-11-18 20:32:42.701 [xLights info] Channels 2, Bits: 4, Rate 44100
2026-11-18 20:32:42.701 [xLights info] DoPrepareFrameData: Start processing audio frame data.
2026-11-18 20:32:42.701 [xLights info] DoPrepareFrameData: Got mutex.
2026-11-18 20:32:42.701 [xLights info] DoPrepareFrameData: Data is loaded.
2026-11-18 20:32:42.701 [xLights info] SetMediaFile: Audio loaded. Audio frame interval 50ms. Our frame interval 50ms
2026-11-18 20:32:42.723 [xLights info] Length 188917ms
2026-11-18 20:32:42.723 [xLights info] Interval 50ms
2026-11-18 20:32:42.723 [xLights info] Samples per frame 2205
2026-11-18 20:32:42.723 [xLights info] Frames 3779
2026-11-18 20:32:42.723 [xLights info] Total samples 8332695
2026-11-18 20:32:43.152 [xLights info] DoPrepareFrameData: Audio frame data processing complete in 451. Frames: 3779
2026-11-18 20:32:46.018 [xLights info] Sequence timing set to 50 ms
2026-11-18 20:32:52.112 [xLights info] New sequence created Type Media Timing 50ms.
2026-11-18 20:32:52.188 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:52.188 [xLights info] Found 0.
2026-11-18 20:32:52.188 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:52.188 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\colorcurves\.
2026-11-18 20:32:52.189 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\palettes\.
2026-11-18 20:32:52.189 [xLights info] Found 0.
2026-11-18 20:32:52.189 [xLights info] ColoursPanel Scanning directory for *.xcc files: C:\Program Files\xLights\colorcurves\.
2026-11-18 20:32:52.189 [xLights info] Found 7.
2026-11-18 20:32:52.189 [xLights info] ColoursPanel Scanning directory for *.xpalette files: C:\Program Files\xLights\palettes\.
2026-11-18 20:32:52.190 [xLights info] Found 10.
2026-11-18 20:33:42.394 [xLights info] Aborting rendering ...
2026-11-18 20:33:42.459 [xLights info] Aborting renderers ... Done
2026-11-18 20:34:15.277 [xLights info] Saving XSQ file.
2026-11-18 20:34:15.279 [xLights info] XSQ file done.
2026-11-18 20:34:15.280 [xLights info] Rendering on save.
2026-11-18 20:34:15.280 [xLights info] iseq below effects done.
2026-11-18 20:39:22.365 [xLights info] Render batch complete: 1 jobs over frames 0-3777, 0 suspensions (0ms), 1 row parks, 307085ms, background
2026-11-18 20:39:22.400 [xLights info] Effects done.
2026-11-18 20:39:22.400 [xLights info] iseq above effects done. Render complete.
2026-11-18 20:39:22.401 [xLights info] Saving fseq file.
2026-11-18 20:39:22.413 [xLights info] FSEQFileIO::Write: wrote 3778 frames x 96 channels to E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\Jungle Boogey.fseq
2026-11-18 20:39:22.413 [xLights info] fseq file done.
2026-11-18 20:39:22.413 [xLights info] E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\Jungle Boogey.fseq Updated in 307.136 seconds
Ben
