So this is a very simple animation setup, in fact I was just creating a demo to test end to end effects on a wreath. My setup is a rasp pi B with a falcon pi hat and a string of 50 pixel lights. I set the string up as a wreath in xlights, and strung along several effects I wanted to test out. I deselected colors from the color bar like cyan as I just wanted rbg and sometimes I will select yellow. When I select each effect in the time line they show as having the correct colors, and down the line I have a modified color set as I changes 2 colors I didnt use to duplicates of red and blue for some effects that I felt were rendering heavy in one or another color. At all times the rendered preview was correct.
However, I then export it to falcon player and the pattern is correct, but the color selection is wrong. It is almost as if xlights ignored my selected color pallet and is just using the default (namely, the color cyan is in the chains of light and should not be). I reloaded X, loaded my sequence, even made my edited color pallet the same through all effects, but the preview sequence color choices are not following over when the sequence is rendered to file. Any ideas?
