Hello,
I have a question regarding the set up of some controllers in xlights & LOR. This is my second year with rgb I have a pixlite16 I am using for the outline of my house. Thanks to so awesome help from you guys here I was able to stumble through last year. This year I bought 2 27channel dmx controllers to run some tombstones for Halloween and trees for Christmas. I will be using 12v dumb nodes for these. I also bought an alpha pix4 control to run a coro spider web that uses 12v pixels.
1. My first question is I know I will be hooking the 27 channel controllers up to the pixlite16 dmx outputs I am just unsure of how to set that up in xlights & LOR? I am only using 3 universes so I would assume I would start it on universe 4 with the same ip as the pixlite??? If so will I need to change the config of the pixlite itself?
2. I guess I am having a little trouble understanding the universe thing. So if I add the alphapix4 controller does it start over on universe 1 since it has a different ip address.
Thank you in advance for your help...
