smeighan
3.1.1 released. Find latest releases here : http://nutcracker123.com/nutcracker/releases/
Matt Brown has fixed/enhanced the Meteor effect. We renamed the Starfield Effect to be "Explode" and "Implode"
Enhancement: Matt added new directions for Meteors. They now can go left and right.
Release notes:
3.1.1: Aug 12,2013 - Bug Fix: (Matt Brown). Matt has fixed the Meteor effect. He has also enhanced it so meteors can fall to the left or right.
We have renamed Starfiled to be called "explode" and "implode"
- Enhancement: (Matt Brown) I made some improvements to countdown & skip blank cells logic. I also changed a couple of method names to make them more clear. Also, the timer now skips if the last interval takes more than 50ms to process. Before it was blocking until the last interval finished (so if every interval took more than 50ms you had a stackup of waiting timer calls to process).
Remember do a "File,Backuo" before installing any new version of xlights.
thanks again to Matt for the nicer meteor effect.
thanks
sean
Release notes:
thanks
sean
