xLights/Nutcracker release 3.3.4. When: Thursday, Apr 17th. 7pm MST, 9pm EST
smeighan
4217 Greenfinch Dr CO 80126
Release 3.3.4. Download new version from http://nutcracker123.com/nutcracker/releases/
New MORPH button, this will move the slider between effect 1 and effect 2 for you!
Text now has option of moving to the center of your diisplay and stopping
Singing faces, now can create scalable faces for the preview.
3.3.4 -Enhancement, (sean). Faces effect now creates a scalable face on your matrix or megatree
-Bug fix, (Sean). Entering a RETURN in the text fields of the the TEXT effect no longer crashes xLights
-Enhancement, requested (djulien): add center-and-stop option to text movement options (new checkbox);
sync text lines; use left/right spaces to delay left/right movement or left/right "\n" to delay up/down movement
-Bug fix (djulien): allow "," within Text lines (caused "not found" error)
-Enhancement (djulien): add MORPH checkbox to enable gradual Effect 1 -> Effect 2 transition;
can be used for ramp/fade, morph text or image, etc.
-Enhancement, requested (djulien): add menu item to clear all effects on this row
-Bug fix (djulien): copy/paste text to Text effect Line 1 - 4, don't interfere with grid
I will give a tutorial covering this release on Thursday, April 17th.
Topic: content of 3.3.4 release.
We will be using teamviewer. Ill start session at 6:45pm MST
Please join the meeting, by clicking on this link:
http://go.teamviewer.com/v9/m93271823
Meeting ID: m93-271-823
If you have a headphone click on the "Voice over IP" on the Teamviewer menu and unmute your headphone to be able to ask questions.
thanks
sean
