Release xLights release: 2026.08
Status
Not open for further replies.
dkulp
Framingham, MA
2026.08 — May 7, 2026​
Enhancements​
  • dkulp — When a JobPool worker thread dies from an unhandled C++ exception, the log now records the exception type, what() message, and the in-flight job name instead of just "unknown exception". Helps diagnose render-thread crashes.
  • agfazio — Add "Also add alias to model" checkbox to the Select Model dialog shown when renaming a missing submodel during sequence load.
  • charlie — Right-click a timing track → "Search for Lyrics Online..." searches LRCLIB by song title/artist (auto-filled from sequence header) and imports the chosen result's synced .lrc lyrics as a phrase-per-line timing track.
  • dkulp — macoS: Hook up Apple "Speech Recognizer" to Apple Intelligence to create timing tracks. Really only usable for very clean voice tracks and "Announcement" kind of things.
  • dkulp — Liquid effect: velocity slider rescaled to allow full use of range instead of just values between 0 and 6 providing visual changes
  • dkulp — Liquid effect: now frame-rate independent. Sequences imported between different frame rates render visually the same instead of emitting more particles per second at higher frame rates. Flow is now particles-per-second; Warm Up Frames renamed to Warm Up Time (hundredths of a second). Particle solver sub-stepping adapts to the frame rate. Existing sequences migrate automatically using each sequence's stored frame interval.
  • dkulp — Liquid effect: Flow slider is now non-linear (linear 0-500 to 2000 particles/sec, exponential 500-1000 to 20000 particles/sec) with a sub-frame accumulator so low slider values emit occasionally instead of jumping straight from 0 to a constant stream.
  • derwin12 — Add duration to lrclib lyric results
  • derwin12 — Add option to add alias when opening a sequence and missing models were found
  • derwin12 — Provide option to select which groups to import to when importing from layout
  • dkulp — Liquid effect: added an Enabled checkbox for particle source 1 (defaults to on)
  • dkulp — Linux: text rendering switched from wxGraphicsContext (Cairo+Pango) to a portable FreeType+HarfBuzz+Fontconfig backend in src-core/. Text and Shape effects can now render on background threads on Linux (previously forced to the main thread because the wx/Pango stack isn't off-thread safe), parallelizing rendering of sequences with heavy text/emoji content.
Bug Fixes​
  • dkulp — Fix House Preview / Model Preview floating panes coming up gray after a perspective load (would only render once manually docked and re-floated). The fix runs the same dock+refloat cycle automatically right after perspective load, preserving the saved float position.
  • dkulp — Fix status bar stuck showing "Batch Rendering ... ## sequences left to render" after cancelling a batch render or batch check-sequence with Escape.
  • MrPierreB — Fix house-preview video export producing dark/washed-out colors on Windows and when uploaded to YouTube. Also fixes Windows GPU encoder selection to prefer the correct hardware encoder (NVIDIA, AMD, or Intel) for faster exports.
  • agfazio — Fix channel numbers not recalculating after deleting a model from the layout.
  • dkulp — macOS: fix Metal compute-render buffer leak. MetalComputeUtilities was double-retaining MTLBuffer/MTLTexture objects allocated via newBufferWith*/newTextureWithDescriptor: but releasing only once, leaking a reference per render-buffer resize.
  • dkulp — Fix scrambled rendering of interlaced animated GIFs (Pictures effect, etc.).
  • dkulp — macOS: process the unselect-effect / choicebook-page-change events synchronously before starting an effect-button drag, instead of posting them async. Posted events were firing inside DoDragDrop's nested event loop, racing with AppKit's NSCoreDragManager and producing a null deref inside NSCoreDragProcessSourceDrag. Suspected cause of the AppKit drag crash.
  • dkulp — Fix EXC_BAD_ACCESS in MetalRenderBufferComputeData::bufferResized when a model has nodes with zero coordinates. Empty-coord nodes now use the same -1 sentinel as out-of-bounds single-coord nodes instead of dereferencing past end of vector.
  • derwin12 — Validate values for fadein/fadeout and add check for bad values in Check Sequence (#6297)
  • derwin12 — Fix Dimensions showing incorrectly in 2D vs 3D (#6294)
  • derwin12 — Some WMA music files were hard crashing. (#6306)
  • derwin12 — Restored the missing assets alert (#6276)
  • derwin12 — Fix in the lua script for batch rendering
  • derwin12 — Imported sequences placed media in inocrrect folder if sequence was not previously saved
  • derwin12 — Fix download model search (#6252)
  • dkulp — Circles effect: GPU (Metal) path was clearing non-circle pixels to (0,0,0,0), wiping the buffer's pre-existing contents. Now leaves background pixels untouched, matching the CPU and ISPC paths.
Changes​
  • dkulp — Windows shader effect: GL work now runs on a dedicated worker thread inside GLContextManager instead of being dispatched to the wx UI thread.
  • dkulp — Render engine cleanup: removed the main-thread effect render queue and all the wx CallAfter / drain plumbing that supported it. No effect now needs main-thread dispatch.
xLights is available for download from https://github.com/xLightsSequencer/xLights/releases/ for Windows/Linux and from the App Store for Mac.
For requests for general help among peers, consider starting a new forum thread: https://auschristmaslighting.com/forums/xlights-xschedule.61/post-thread
Status
