Release xLights release: 2026.21
Status
Not open for further replies.
dkulp
Framingham, MA
2026.21 — November 24, 2026​
Enhancements​
  • dkulp — Layout, controller and effect preset changes saved by someone else to a shared show folder are merged with yours when you save: you choose only where you both changed the same thing, or where they deleted a model the open sequence has effects on (keep it, delete it with its effects, or map the effects to another model), and a report lists renames and broken references
  • dkulp — Shared show folders: changes someone else saves to the layout, controllers or effect presets are brought into the open show once playback stops, merged with your unsaved edits; where you both changed the same thing, a status bar notice offers Review
  • dkulp — Shared show folders: warn when opening a sequence someone else has open, and show who else is editing the layout or controllers in the status bar
  • dkulp — Warn instead of silently overwriting layout, controller, preset or sequence changes saved by someone else to a shared show folder
  • dkulp — Autosaves in a shared show folder are kept per computer and only offered back on the computer that wrote them; restoring one no longer discards changes someone else saved since (merge them, save as a copy, or restore anyway)
  • dkulp — Opening a sequence saved before models were renamed in the layout (here or by someone sharing the show folder) renames its rows to match instead of asking about missing models
  • dkulp — Offer to merge the conflicted copies Dropbox, iCloud, OneDrive, Google Drive or Syncthing leave of the layout, controller or preset files; the copy is then moved to the Backup folder
  • dkulp — Show files are saved in one step, so a crash or a sync client never sees a half-written file; tags, permissions, creation date and hard links are kept
  • dkulp — Undo now covers adding, deleting, renaming and reordering timing tracks, adding, removing and reordering models in the sequence, timing imports, tags, song structure and sequence face edits
  • dkulp — Import Effects (every format, and the automation import commands) can be undone in one step, including the timing tracks, models, images and faces it added
  • dkulp — Shift Effects, Shift Effects And Timing, Shift Selected Effects, Convert Data To Effects, Promote Node Effects and the clearModelEffects / cloneModelEffects automation commands can be undone in one step
  • dkulp — Creating, linking, unlinking, renaming and deleting effect symbols and Convert Symbols to Effects can be undone
  • dkulp — Sequence media edits can be undone: add, embed, extract, rename, remove, re-embed, re-select, bulk find/copy, embed/extract all, and removing unused media and AI images
  • Upercat — Custom Model: drag with the middle mouse button to pan the grid (#7416)
  • derwin12 — Layout: Esc exits the active model drawing tool (e.g. Single Line)
  • scott — Lyrics: Generate AI Image for Phrase adds a Pictures effect with an AI-generated image for the phrase's time range
  • scott — Controller Visualiser: drag a port's label onto another port to move all its models there, or onto the model pool to remove them
  • derwin12 — FPP Connect: the upload log and Completed list show whether each controller's media was uploaded (with its size), already up to date, or not found
  • heffneil — FPP Connect upload window: draggable divider between the controller gauges and the Completed list, which now gets any extra window height
  • PeteMatthews — ILightThat controllers: upload grouping, zig zag and start/end null pixels, and refuse settings the board's firmware does not support
  • dkulp — iPad - Layout, controller and effect preset changes saved by someone else to a shared show folder are merged with yours when you save: you choose only where you both changed the same item, or where they deleted a model the open sequence has effects on (keep it, delete it with its effects, or map the effects)
  • dkulp — iPad - Shared show folders: changes someone else saves to the layout, controllers or effect presets are brought into the open show once playback or a drag ends, merged with your unsaved edits; where you both changed the same thing, a banner offers Review. Can be turned off in Settings
  • dkulp — iPad - Shared show folders: warn when opening a sequence someone else has open (open anyway or read-only), and show who else is editing the layout or controllers in the layout editor
  • dkulp — iPad - Warn instead of silently overwriting layout, controller, preset or sequence changes saved by someone else to a shared show folder
  • dkulp — iPad - Autosaves in a shared show folder are kept per device and only offered back on the iPad that wrote them; restoring one no longer discards changes someone else saved since (save as a copy or restore anyway)
  • dkulp — iPad - Timing imports, new timing tracks (every type, including AI lyrics, tempo, chords and onsets), renaming, deleting and making a timing track variable, moving rows, tags, sequence faces and song structure edits can be undone and redone
  • dkulp — iPad - Import Effects, SuperStar import and Import Lyrics can be undone in one step, including the timing tracks, models, images and faces they added
  • dkulp — iPad - Renaming and deleting effect symbols and Convert All Symbols to Effects can be undone
  • dkulp — iPad - Media manager edits can be undone: add, embed, extract, rename, remove, re-embed, replace, embed/extract all, and removing unused media and AI images
  • dkulp — iPad - Song structure boundaries can be dragged in the waveform strip; each drag is one undo step
Bug Fixes​
  • dkulp — Undo could change or delete the wrong effect after some edits, lose effects deleted from a layer that was later removed, and do nothing after a timing track was renamed
  • dkulp — Undo of effect settings panel changes restores the effect exactly, including its type and settings added or removed; changes to a second effect of the same type could not be undone; edits after a pause of over a second are their own undo step
  • dkulp — Undo of removing a layer brings back the layer's name and effects
  • dkulp — Split Effect and Paste as Layers are undone in one step (the first Undo after a split did nothing); a Morph assist double-click can be undone
  • dkulp — Undo of Auto Label and Convert Effects To restores the previous label or effect type; undo of deleting an effect linked to a symbol keeps it linked; the automation deleteEffect command can be undone
  • dkulp — Undo of Import Lyrics and Breakdown Phrases/Words restores the timing track's previous layers instead of leaving them empty; Remove Words/Phonemes can be undone
  • dkulp — Servo linked start/end values: undo takes back the change to the neighbouring effect along with the edited one
  • dkulp — Shift Effects no longer moves locked effects (Shift Selected Effects could leave one before the start of the sequence)
  • dkulp — Promote Node Effects no longer adds an empty layer when nothing can be promoted
  • MrPierreB — Bulk editing a DMX channel slider could clear value curves on unrelated channels of other selected effects
  • dkulp — Bulk editing a setting could crash when a submodel or strand row held effects of an unknown type
  • dkulp — Adding or removing layers on a submodel or strand row while it rendered could crash
  • dkulp — SingleStrand FX with exactly 6 colours on the Default or "* Color Gradient" palette could crash, and its gradient left out colour 5
  • derwin12 — Layered Arches with an Inside starting location rendered Strand effects on the wrong nodes when the layers had different sizes
  • MrPierreB — Moving Head Adv: position zones were not applied when the effect was on a group containing the model
  • derwin12 — Moving Head Adv: the position zone indicator ring stands upright around the yoke again instead of lying flat around the base
  • derwin12 — Select Effects listed models with no effects matching all of the Effect Type, Render Style, time and colour filters
  • derwin12 — Effect Presets: presets saved with a timing track selected showed a black preview instead of the animated GIF
  • NotAFlightRisk — AI Lyrics from Audio could add a very short word as a zero-length mark on 50 ms sequences
  • dkulp — AC mode: turning lights off over a range that fully covered a locked effect could hang xLights
  • dkulp — Saving pixel edits to an embedded image from the Pictures assist window was silently discarded
  • dkulp — Extract All left SVG, shader and text media under their old name while effects were pointed at the extracted file
  • dkulp — Renaming embedded media to a path effects already use (but that isn't embedded) no longer fails with "already in use"
  • alex — SubModels: Import Custom Model Overlay ignored the chosen alignment column and placed the overlay upside down; all 9 positions now work
  • alex — SubModels: Import Custom Model Overlay filled in the empty cells of the outline, importing it as a solid block instead of its shape
  • dkulp — Generate Custom Model could crash when the video returned too few frames
  • derwin12 — Print Layout printed a different, shifted part of the layout than the dialog's preview showed
  • dkulp — Bulk Edit Properties could crash when closed while a property was still being edited
  • dkulp — LOR S5 import: Marquee took its speed from the wrong field
  • dkulp — LMS import: channels with the same name on different networks got identical names
  • dkulp — HLS import: strand names lost their last character, so Map CCR/Strand found no nodes
  • derwin12 — Layout Controllers page: the selected controller's red/green status light refreshes on its own (and when clicked) without setting a ping interval
  • derwin12 — FPP Connect no longer adds uploaded .eseq effect files to the selected playlist as sequences (#7411)
  • derwin12 — FPP Connect with "Keep window open" added sequences from earlier uploads to the playlist, not just the ones selected (#7395)
  • derwin12 — FPP Connect: an effect sequence with no channels on a controller reports "Skipped - no channels on this controller" instead of "Already up to date"
  • dkulp — FPP Connect could crash during upload when an FPP asked for a password
  • derwin12 — FPP Connect / Discover could show most FPP controllers as unavailable when some were set by a slow-to-resolve .local hostname
  • derwin12 — Falcon upload: the serial port start channel limit now only applies to an F16V3 in DDP mode, not E1.31/ArtNet or other V3 boards
  • derwin12 — HinksPix DDP upload: DMX did not work when the controller didn't start at channel 1 (#7297)
  • dkulp — HinksPix Export could crash on open when a saved playlist listed the same sequence twice, or when reading a sparse FSEQ
  • dkulp — Mac: starting playback could crash right after a sequence's audio was loaded
  • dkulp — Mac: closing xLights could hang and new render work could start slowly on a busy computer
  • dkulp — iPad - A deleted model no longer comes back after saving the layout
  • dkulp — iPad - Undo of a large step (such as pasting 60 effects) only partly reverted it
  • dkulp — iPad - Undo after Promote Node Effects or Convert Data to Effects undid the previous edit instead, and Redo after it and other bulk edits did nothing
  • dkulp — iPad - Dragging an effect setting slider or typing a value is one undo step instead of one per change
  • dkulp — iPad - Breakdown Phrase on a single mark can be undone (a later undo could revert the wrong edit); undo of Breakdown Word(s) no longer leaves an empty phoneme layer
  • dkulp — iPad - Starting playback could crash right after a sequence's audio was loaded; closing could hang on a busy device
Changes​
  • scott — Controller Open / Open Proxy buttons stay enabled while outputting to lights
xLights is available for download from https://github.com/xLightsSequencer/xLights/releases/ for Windows/Linux and from the App Store for Mac.
For requests for general help among peers, consider starting a new forum thread: https://auschristmaslighting.com/forums/xlights-xschedule.61/post-thread
Status
