XSchedule help
Jandrews755
Finally got my show up and running only a couple days late. Only issue I'm having is when I play off xlights the tune to matrix works perfect but when I put it into xschedule it goes all funny any ideas? It's strange that it works perfect in xlights when I output to controller but not in scheduler. Iv attached pictures of what I'd dose with xlights then xscheduler I know it's a busy time but any gp would be much appreciated
Have you got xSchedule pointing to the same show folder as xLights?
Looks like the channel defintions are slightly out.
First, be sure that you've saved your layout and networks in xLights. xLights recalculates it and will play properly, but if you skip saving then xlights_networks.xml can be out of date. Then, be sure to point to the right show folder like Skymaster said, for the same reason, xSchedule will be reading that xlights_networks.xml to know which channels to put in which packets.
still having no luck. do i need to setup a matrix in xcsheduler i haven't needed to in the past
