Play Music on FM
christmasmatt
is this legit?
When I click the link, I see this:
So given it is the exact ad I bought form absolutely.
This is the same as the CZE-05B linked in the other thread, just with a different badge on it.
Skymaster
Crazy elf
Western Sydney
I can't comment on the legitimacy of the ad, however Aliexpress does have buyer protection built into it. It is advertising the same unit as all the others.
christmasmatt
do you know of any other good Fm transmitters for a bit less? I only need about 100 - 200m.
do you think Ali express is worth the extra $20?
KiwiPhil
Boondall, Brisbane
Skymaster
Crazy elf
Western Sydney
Locks
Hi guys
First time show set up here, this is probably a silly question but any thoughts why im not getting any audio output on my Kulp 16a/b. Im only going out via the 3.5mm plug to headphones to test. Sequence has audio in xlights and lights are all good working at the moment? Is there something i havent enabled on the fpp?
Skymaster
Crazy elf
Western Sydney
Check the FPP Settings-> Audio/Video page and make sure the correct audio device is selected
Locks
Yeah i was pretty sure i did. I might remove it then re upload it again to cancel that out at least. Thank mate
vk3heg
Ballarat
I think I’ll go with the Ali Express because it's a lot cheaper. I'm probably only gonna use it for next year. Thanks for your help though.
Your choice, but there is a reason the CZE units are recommended... My first year of using a cheap device (One that plugged into a cigarette socket), as a total balls up... It was lucky to make it across the road, and there was 6 meters to even get to the foot path.
Skymaster
Crazy elf
Western Sydney
You have the "Audio Output Mixer Device" set to PCM.. Try "speaker".
Te PCM device is the correct output when using the inbuilt i2s audio adaptor as part of the K16AB board. The BBB's do not have an onboard sound card and as such do not have 'Speaker' available like a Pi.
After checking with @Lcoks in chat last night, the audio files were indeed missing on the system.
vk3heg
Ballarat
That was the first thing I noticed.. But yeah, not having the media files there will do that.... o_O
