Experimentation - Xlights / Xschedule running on Raspberry Pi 4
Derf
am now a 5v hypocrite
Narellan Vale, NSW
Hi All,
Have been playing around with the principal of running Xlights / Xschedule on a raspberry pi as an alternative for a dedicated PC for running virtual matrix's. This is extremely experimental and will probably not work for everyone.
BACKGROUND:
During the year I purchased $6 AUD p4 panels to give them a shot as the price was to good to be true. if you want to check them out you can find them here: https://www.aliexpress.com/item/33021998613.html?spm=a2g0s.9042311.0.0.546f4c4dhLO8LD
From the seller he recommended purchasing linsn sending and receiving cards to drive the panels. (Worst mistake I think I have made in this hobby second to starting the hobby). These linsn cards are just dark magic that requires some serious voodo work to get them to function property. Not only did I find it near impossible to get them working in FPP they randomly stopped working and requires a MAC address that isn't easy to find.
So that is were the sending card comes into play. The seller recommended to purchase this sending card https://www.aliexpress.com/item/1000001884244.html?spm=a2g0s.9042311.0.0.546f4c4dhLO8LD which takes a DVI input and acts like a secondary monitor to your windows PC. This monitor will display the Panel cabinet size of the 1920x1080 signal for example my test screen is 320(w) x 192(h).
Diagram:
Spoiler content hidden. Log in to see this content.
So the idea was to use Xschedule to play a virtual matrix which will send captured video by the sending card to the receiving card and displaying items from a sequence, etc.
MATERIAL LIST:
  • Raspberry Pi 4 (Make sure you have a fan / heat sink it gets really hot)
  • HDMI TO DVI
  • Panels
  • Linsn Sending Card
  • Linsn Receiving Cards
  • USB to Ethernet adapter (Currently the build of Windows ARM does not support the inbuilt ethernet adapter)
  • Micro HDMI to HDMI Adapter for Pi
  • DVI Cable
SETUP:
This thread has been created to experiment with the principal of Xschedule on a PI. I will post the setup of a Linsn card on a future thread.
1. I Started with grabbing an Image of a very experimental version (not official windows image). There is a team working on a fully supported version of windows ARM however is in its early stages of development. If you would like to try this you can download an experimental version here:
2. For this you will require a tool for burning the windows image to an SD Card (equivalent of etcher) WOR TOOL:
3. Run through the setup and select the .wim file that was previously downloaded. Tell the installer to get all drivers, etc from the internet. If you can get stuck you can follow this guide
4. Place the sd card into the PI, Connect the usb to ethernet adapter and give it an internet connection.
5. Wait. The installation process of windows onto an SD card is extremely slow and takes a while to expand its file system.
6. Once everything has finished you will be prompted to give it a name and a password.
7. Installation completed.
You should now have a working windows ARM image onto your Raspberry Pi Photo:
SOME IMPORTANT NOTES:
- When you normally download a windows executable you download either a 32bit architecture or a 64 bit architecture. A Raspberry Pi is neither a 32 bit or 64 bit architecture it is ARM architecture. This windows images has inbuilt emulators to run only 32 bit images. 64bit programs will refuse to run.
- This image is currently extremely experimental and your results may vary. On idle it was noted that the CPU sat around 12% and 0.8GB ram.
INSTALLING XLIGHTS:
As you normally would I went to xlights.org and found the latest version of 32bit xlights to give it a run. Windows also installed the required C libraries as a standard installation would. That was pretty much it. Everything loaded and operated fine from my quick experimentation. see below:
Xschedule:
Xlights:
Virtual Matrix running:
PERFORMANCE:
From my quick testing on this the performance on a standalone Xschedule with a Virtual matrix is perfectly fine it runs the sequence without any problems. Issues start to commence when you load Xschedule into FPP remote mode and it starts attempting to communicate data. Whilst no Hardware resources are being fully consumed the virtual matrix runs at about 2-3 FPS which is far from ideal. I am currently experimenting to find a way to stop the data transmission from Xschedule during a sequence as when in remote there is large amounts of data being sent and received from the pi for a single matrix (40mbit each way). (Any input would be great to try out).
CONCLUSION:
Currently without to much investigation it doesn't run as good as FPP which it shouldn't. FPP is a dedicated linux software kit designed for it. I don't personally think xschedule / xlights a full scale Windows app was ever intended for this without hardware that the foundation (libraries) of xlights is expecting to see!.
It was fun to experiment this principal as a Pi is is a good cost bracket for a problem like this. As mentioned before this experiment was only because I was sold a Linsn card. (never again :D).
Anyway hope you enjoyed the read if you have ever tried this or have any comments post below interesting to try a few more things out.
Jorge Bolivar
Cleveland, Ohio
I was thinking xLights runs on linux. Windows in Rpi is not my cup of tea. May try but after get my current display functional. Thanks for share.
dkulp
Framingham, MA
Why not just use FPP Virtual matrix -> HDMI/DVI -> Linsn sender? If using a sender card, much of the complexity of the FPP Panel/Linsn setup goes away as it's just HDMI out.
darylc
404 darylc not found
@dkulp
Because FPP upscales the pixels on the HDMI output. The Linsn requires 1 pixel on the HDMI port to represent 1 pixel in the sequence/screen. FPP makes 4 or 16 or however many it feels like on the HDMI per 1 pixel in the sequence.
dkulp
Framingham, MA
That's something that would take a couple hours to change, but no one has ever logged a request about it. Things that aren't logged don't get changed.
Derf
Narellan Vale, NSW
Set outputs to xlights only?
Thanks for that. Was trying to find out what it was to set it to not send data.
I think there may be a slight bottle neck on the RPI / Windows image that is causing the USB ethernet adapter to run at max 20mbit. As the image is lagging every now and then but definitely not as bad as when the pi was also outputting data. Does that traffic appear to be correct @keithsw1111 for sending sync only packets. The entire matrix is 184,320 channels and it will not output anything if I delete the fseq file so it must be getting the matrix data from the locally stored sequence and not the master?
Raspberry Pi Task Manager:
Main Computer Xschedule Sending data to controllers Task Manager:
Xschedule total network activity:
The activity in this is also sending data to a p5 matrix of the similar channel count so it could be 50/50%
It seems like a lot of data for just syncing matrix timing for a matrix or does this indicate that something is wrong and it is sending all of the data from the master?
tooms
12v4life
Kalgoorlie
I would try using wireshark to capture ip traffic, you can also use wireshark to get a better measurement on throughput & bandwidth. Windows taskmgr and resmon are pretty average at guessing system resources utilisation.
dkulp
Framingham, MA
FYI: FPP 4.3 is now out and the normal FPP VirtualMatrix should work find for this use case now. The VirtualMatrix can be setup to maintain a 1:1 pixel mapping (so no scaling) and stuck in the upper corner (or elsewhere) so the sender card should be able to grab the correct area it needs.
