Play Music on FM
Skymaster
Crazy elf
Western Sydney
If you're using normal FM broadcast, there is none. As soon as you introduce anything digital, like Bluetooth or streaming, it becomes unusable.
Skymaster
Crazy elf
Western Sydney
This is one of the common ones used. From an Aussie supplier.
You can probably pick it it up marginally cheaper on AliExpress/Amazon.
Jase
Melbourne Australia
Yep I've got one of these and it works super. Goes a couple of streets easily and I have it on lower power!
Freman
Uh Oh Elf
Would you connect it to the computer running the software?
Yes, you would connect it to whatever device/computer was running your show with audio. In fact in my setup it's connected to a USB sound blaster plugged into the pi that runs FPP to run the shows.
christmasmatt
Does anyone know if this would work with my setup (DMX2-24) with a laptop in a garage?
I want to play on an FM frequency.
Does anyone have any suggestions for other transmitters that would also work but are a bit cheaper?
How legit are the AliExpress transmitters?
Skymaster
Crazy elf
Western Sydney
When I click the link, I see this:
So given it is the exact ad I bought form absolutely.
This is the same as the CZE-05B linked in the other thread, just with a different badge on it.
