Strange things with my lights?
badger4543
S.E Melbourne
Do I have some sort of funky Channel over lapping issue? Don’t remember having this issue last year? Haven’t done any repairs or changed anything from last year (same layout and same controller ouputs) other then updated fpp. When on full red, green and blue on the test page I get some strange colour changes in random area of random props, using a pix lite 16, and pix lite 4 running off my rpi 3b+ with fpp on it..
First pic was meant to be all red, second all green third all blue
Skymaster
Crazy elf
Western Sydney
Is it at about pixel 170/340/510 etc?
If so, check your universe size. One is probably set to 512 channels, the other to 510
badger4543
S.E Melbourne
only warnings i get from the test sequence tool are in the screen shot
badger4543
S.E Melbourne
What about on the controller end too - in advatek assistant?
ill have to check tomorrow havent looked at that for the last few seasons as its a pain have to connect them to the router and change ip adress on them to get access to them
franky_888
Medowie
I highly recommend using FPP display testing (as long as you've pushed your model data with FPP connect) if you can.
Much easier to spot mistakes with output wiring (ie props in the wrong order etc)
badger4543
S.E Melbourne
i was using the fpp test page, ill do a further investigation tomorrow, and double check everything.. what is meant by "pushed your model data with fpp"
