Release 2019.72 Released
keithsw1111
Kellyville, NSW
2019.72 December 28 2019
— enh (gil) Zoom to mouse pointer in Layout
— enh (gil) DMX Models should now work (they do something) for all effects
— enh (keith) Add zoom to the wiring view
— enh (keith) Lay the groundwork for a future where only xSchedule is released as 32 bit
— enh (keith) Add an Any import type which shows all supported input types when importing sequences
— bug (gil) Fix PolyLine Icicle drop channel numbers when Blue Square is selected
— bug (keith) Fix xSchedule schedule clone does not work right
— bug (keith) Bunch of cleanup to build process to eliminate unnecessary complexity
— bug (keith) Fix hang when opening audio file fails
NOTE: This is very likely the last ever 32 bit version of xLights on windows. I may release a 32 bit version of xSchedule from time to time as some folks may be still using old 32 bit machines to play their shows but I really think if you are sequencing in 32 bit it is time for an upgrade.
franky_888
Medowie
Gil closed my github issue this morning stating that they have updated the xlights website with the new C++ version. So make sure you all run this as well when updating :)
