Closed ACL Strobe Mk 2 bulk buy - ends 12 September 2014
Status
Not open for further replies.
Bulk buy close date
Sep 12, 2014
Bird
LOR user
Cincinnati, Ohio, USA
tmcteer said:
Bird,
A couple of pics would keep us going a few more days...... :)
Tom
Interesting concept. The C9 covers were loose acting as packing peanuts for the LED's and sleeves. :)
I have to count out the LED's and we should be good to go.
Wow. I thought you would have got it to you last Monday or Tuesday.
Bird
LOR user
North American shipping update.
$13 bdt
$19 roterhead
$13 tlh
$13 tmcteer
Should have received tracking numbers from PayPal last night or this morning
$14 drlucas
$21 DrNeutron
$13 arw01
$13 dougd
$13 rogerdc46
Will PM tracking numbers to you today
$13 imbluenote
$13 KenL
$13 loveroflife96
$13 Skunberg
SmartAlecLights
Murray Bridge, S.A.
I did'nt buy any, but i soldered 48 of them up for ron.
Out of 48 of them 46 worked (i made up a test jig)
has anyone experienced this yet?
Is there any chance of the firmware (or hex code)
so i could try an reflash them (if the pickit3 see's the ic that is)
thanks.
Ps. for the 46 that worked.. there super bright, (just dont look into them) :)
DrNeutron
Just starting in this crazy hobby
Glace Bay
Wow Bird, you are super quick
Thanks.
$13 bdt
$19 roterhead
$13 tlh
$13 tmcteer
$14 drlucas
$21 DrNeutron
$13 arw01
$13 dougd
$13 rogerdc46
$13 imbluenote
$13 KenL
$13 loveroflife96
$13 Skunberg
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
thanks.
Just getting into mine today.
Any pics of your test rig........
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
1st 48 done and tested.
2 x bad strobes.
1 x chip board that produces smoke.
1 x assembly strobe is constant ON - no does do the flashy thing.
1 x chip assembly dead.
Any of the above could be my first attempt at circuit board assembly since I was 9ish and making Crystal sets.....who remembers then? ??? ? 8)
I remember making a crystal set :)
Because of the clearance between solder joints and components it is pretty much an absolute must that you should check your solder joints with a magnifying glass. I'd recommend checking after the resistors and leds have been fitted and then a second check after the wires are fitted.
There are a couple of points where the solder joint you need to solder up and the adjacent bit of copper/component will let out the magic smoke if they meet in anger. Having the power connected around the wrong way will let out the magic smoke too as I know from 1 of the proto boards I knocked up.
2 x bad strobes.
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
How I intend to make mine up.
Procedure
1 - Tested assembly.
2 - Inserted assembly into Pixel tube
3 - Hot Glued tube into outer casing
4 - Used glued 12 x 3 heat shrink. 12mm fits snug over casing and shrinks down to 3mm wires.
Take care with shrinking around casing as it can pull off if too aggressive with heat.
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
Alan, I can test OK on straight 5V DC supply.
When I connect to a Ray Wu 27 Channel DMX controller and have 4.72V outlet supply it will not fire......... ???
Are they critical for 5VDC?
What is the voltage range?
Status
