ECG-D2
Dennisl
Burbank il
I have a ECG-D2 trying to figure how to configure the two ports .How do you change the ports to different universes or can they only be universe 1 and 2 I want universe 12 and 13 is that possible thanks Dennis Laff
damo1271
Adelaide
Hi Dennis
you should be able to use any universe number you like. I use universe 20 and 21 on mine. As long as the universe number matches in both the D2 config and your sequencer config you should be fine.
Superman
Ipswich-QLD
you will need to access the D2's User interface by typeing the IP address for it into your Browser.
Your universes can be changed in the Slave configuration tab.
your default username and password will be either:
admin/<blank>
OR
admin/ EthConGwy
