Help adjusting RGB values?
robertmasters
Texas City, Texas, United States
Hey I have some LEDs around my room that are connected to a controller app on my phone, is there an app the lets you adjust the actual RGB values? Mine only has a color wheel. Idk if the adapter needs this specific app to work but any advice is appreciated.
Adsy
Sheidow Park SA
Most of these controllers are fairly cheap so the apps are going to be limiting to some degree. I still have a few floating around and have to say i haven't
come across that sort of feature. You could You tube led controllers which show features of a controller. Are these RGB only or the addressable type?
Katekate
Portland, Vic
generally you are going to be stuck with the one app.
your only option is going to be swapping out the controller.
fugley
try changing the app... a lot of cheap controllers will work on many different apps
