House outline in electrical trunking thoughts
Annoying Elf
Christmas Light world
I'm not a 100% sure but it definetely has UV stabilised printed on the back of it I've seen this used on the exterior of buildings before but I can't say I know weather it will stay as translucent I spose only time will tell
I suppose I'll take a look at Bunnings when I'm next free.
I have a scrap of smaller trunking, so that might get placed outside for the next few months.
stevelee
Bathurst
They look good. I'm surprised how well the light comes through the plastic. My problem is my OCD would not like the inconsistent pixel spacing! LOL!!
My OCD would have me drilling hundreds of small holes and cable tieing each pixel into place.
stevelee
Bathurst
40x25 duct/trunk from the electrical wholesalers
Magnets from eBay or local maybe Bunnings
Stainless screws and nuts from a hardware store (do not do up really tight it will break the magnets
A dab of silicon or hot glue so the nuts do not come lose
11.5mm-12mm (test first) drill to the space you want or what your string will let you and your done
1 - 4m length I have about 80 in there 4-6 magnets.
I was wondering if that would work. Thank you for proving it.
I am thinking to permanently mount the apexes for my roof line. There's no gutter and nothing magnetic to stick it to on them, so they'll be screwed up.
TerryK
Retired Elf
West Central Ohio
A thought regarding UV deterioration, there are aerosol UV coatings available to help protect plastics, vinyls, and such. I've never used them so no idea on how long a coating would last or how often it would need reapplied.
Melinda
This is the exact thing we were thinking of doing with this product. Except drilling the holes though, which was going to be a lot of holes lol. I'm also surprised how much light comes through, that's great! Thanks for posting. Ended up deciding to go with corro strip this year for convenience and time, but definitely keen to hear how they go in the weather.
Annoying Elf
I went to Bunnings in the weekend. Sure enough, the NZ DETA stock says UV stabilised.
I'll give a scrap piece a go.
MichaelF5
West Hoxton
hmmm the feel I've had looking at the strips and Stevelee's CDO is your best bet is to get the IP 68 strips and aim them back at the house so you don't get the individual pixels showing and if you tuck it with some aluminium extrusion so the sun does not hit the strip you'd tick most boxes
Annoying Elf
Just a little bit past 16 weeks ago.... I have finally spent 3min of my life sticking a bit of plastic to a brick.
It's not laziness, it's putting it out when the weather is getting hotter ;).
I have 4 layers of gaffer tape in the middle, so there is a comparison to non-UV exposed area when taken off.
Middle has overlap as normal, ends are offset to see the internal channellings effect with UV exposure.
Zip tied to a brick so it doesn't blow away. Also because it simulates hot bricks on the house during the day, If I used this I would have it mounted onto the bricks with wall outlines.
Grozzy
Oh great, the idiot's back
I used the 25mm x 16mm one and the square nodes fit perfect. Was originally going to drill out the cover but I had plenty of spare Boscoyo strip so used that instead.
This has been up since November last year and it has not gone brittle. The only thing I have noticed is that they do need a bit of support along the way as they can droop, plus the Boscoyo strip expands and contracts with the weather and I haven't zip tied or fixed it anywhere, drilling out the cover would definitely make it look neater and give it some rigidity.
Annoying Elf
Looks great, and nice to know your Bunnings DETA trunking has survived.
There's your inspiration @Zuseleets .
TANSA
Sparky with Blinky Lights ;-)
Bentley Park
No, I did not, and it also holds the power injection wires.
But I drilled the side not the lid or base.
(Bullets)
Annoying Elf
View attachment 18274View attachment 18275
Ha, activity on this post. I forgot about the bit sitting outside.
It doesn't look any different since it was placed outside over a year ago.
The Hobo
Looks like i've locked in my solution then - will be using the 50x25mm DETA trunking and drilling a million holes. Fun times.
