Is this 1 or 3 Pixels?
orlandoal
Angry Elf!
Orlando, Florida
Hi Everyone,
I only started LED Pixels this year, previous years were A/C, so still very much on a learning curve.
I wonder if anyone can answer a question for me or at least give me some thoughts. I purchased a bunch of item below from Ali Express.
"DC12V WS2811 26mm diameter transparent cover LED Module Exposed Point Light 3 leds 5050 SMD RGB Chips led pixel waterproof IP68"
The actual light comes with three LED's, description says "3pcs SMD 5050RGB LED with 1 WS2811 IC" does this count as 1 or 3 pixels? I have tested the lights and it is set as 1 pixel in xLights and all three light up, so it is 1 or 3 or are the three just for a brighter light?, I did say I was still on a learning curve.
Picture attached to help.
Thanks for any feedback.
Alan
Indigogyre
Journeyman Elf
From your description it sounds like it is only one addressable pixel that just happens to control all 3 leds at one time. They are addressed as a single pixel per unit. So 2 units are 2 pixels.
orlandoal
Angry Elf!
Orlando, Florida
Thanks a lot for your answers, I was thinking along the same lines as well, but as I said I am new to this and wanted to make sure I was not doing anything wrong by setting it as a single pixel in xLights.
Merryoncherry, you are correct, these lights are way brighter that just one pixel, although now too late, I am going to install them in my plastic Pumpkins as flickering lanterns in next years Halloween offering.
They will hopefully look pretty good.
