Smart receiver help
Jandrews755
How do I configer my falcon smart receivers A & B in xlights. Iv plugged them in set the correct switches for a & b and the Terminator switch on receiver B but am now unsure what to do next to configer them any help would be great thanks
Annoying Elf
Christmas Light world
In visualiser, set the port you would like it to be on.
Right click on the prop, set smart remote to A or B.
At least this is what I think it is... I have never played with smart remotes.
Christmas30
I can answer this later when I'm back home and can login on to the lighting server but I'm. Out if you could wait till. Later today I can screen shot what to do unless somebody else answers before me
Srmorgan
There is also a serial port setting that needs to be changed so the f16 uses the ports the correct way. I’m not home either so can’t tell you how that needs to be set up right now.
orchidman33
here is how I've set mine on the visualation. I am using "A" and "B" like you.
drag the second prop over to the same output and this time
Annoying Elf
I helped Jandrews755 last night on Zoom.
It was as @orchidman33 and I said, setting smart remotes A/B with visualiser.
Extra part was setting it for the serial output ports on the F16v3, not a differential expansion.
Jandrews755
Thanks again for your help I knew it would be a simple fix
