USB sound card configuration for BeagleBone Black with FPP
joeyschinella
just looking for some help setting up sound card.
running HE123D controller on a beagle bone black and purchased on generic USB sound card from amazon.
when I plug it in the USB port, are these items normally plug and play or is there a driver / or similar i need to run first.
thanks in advance"
Johnnyboy
Perth
Head into FPP settings and update the output to the sound card you are using
Indigogyre
Journeyman Elf
You might need to use a powered hub on it. Sometimes the power draw causes issues.
Skymaster
Crazy elf
Western Sydney
The underlying Linux OS will need to support the card. There is no specific driver installation that you need to run.
If it doesn't appear in the drop down as mentioned by @Johnnyboy , first try the powered hub option that @Indigogyre recommends. If this still doesn't work, then it's likely that the device isn't supported and you would then be better off using something such as the Sound blaster play 3 which is highly recommended and used within the community
joeyschinella
If it doesn't appear in the drop down as mentioned by @Johnnyboy , first try the powered hub option that @Indigogyre recommends. If this still doesn't work, then it's likely that the device isn't supported and you would then be better off using something such as the Sound blaster play 3 which is highly recommended and used within the community any
joeyschinella
any tips on getting sound blaster 3 working , one got delivered today , and not being detected by fpp .its plugged straight into the usb port , does it need to be plugged into a powered USB hub
thanks in advance
